Stay Healthy With This Phone Charger
If you live in an area where it gets cold in the winter, chances are the flu has got you directly in its crosshairs. And, if you’re anything like me, you probably end up using hand sanitizer by the bucketful during these months, but what about your smartphone? Considering your hands touch that more than anything else, shouldn’t it be sanitized as well? Well, with the PhoneSoap Charging Sanitizer, it can be.
The PhoneSoap Charger is a USB charging dock that features two built-in UV sanitizing lights. These lights kill bacteria and germs on both the front and back of your phone. The sanitization process happens as your iPhone charges, so you can be sure your phone is clean every time you pull it from the dock.
The PhoneSoap Charger also has a unique set of acoustic outlets that allow audio to play through the charging station so you can continue to use your phone as an alarm clock.
Happy germaphobeing.
You can purchase a PhoneSoap Charger for $55.
Andrew is a geek, Apple enthusiast, blogger and coffee lover from Chicago.
